how to replace rear tailight bulb?
Old Nov 9, 2002 | 03:35 PM
VADE-R's Avatar
New User
Default how to replace rear tailight bulb?
in the owners manual it says that for the itr, you cannot change the bulb and that you have to go to the dealer, all i see different, from other versions(gs...etc)is that the itr has that bar in the trunk, w/ 2 bolts to remove, is there a problem w/ removing the bar or is there another reason why the manual says that, thanks
Old Nov 9, 2002 | 03:37 PM
uNF$@#!'s Avatar
Default Re: how to replace rear tailight bulb? (VADE-R)
stop smoking the crack
go out, get a 12mm socket and take the bar off, then proceed as usual
Old Nov 9, 2002 | 03:49 PM
Bbasso's Avatar
very easy to change bulb just get hammer and smash hole in red lense and change bulb, as for red lense just have venting hole for light bulbs.
If you don't think thats the best way then take off panel in hatch adjacent to rear section of car then remove all the 12mm nuts and then push studs out and back of light will apear.
Old Nov 9, 2002 | 05:52 PM
sil's Avatar
sil
Default Re: how to replace rear tailight bulb? (Bbasso)
this method will also prevent condensation..
Old Nov 9, 2002 | 06:44 PM
GettaluvR's Avatar
New User
Default Re: how to replace rear tailight bulb? (Soup ****)
u dont actually need to take off the bar @
at least i did mine without taking the bar out
Old Nov 9, 2002 | 08:17 PM
B2FiNiTY's Avatar
Default Re: how to replace rear tailight bulb? (GettaluvR)
No need for the bar to be removed...just easier though.
Old Nov 9, 2002 | 08:40 PM
VADE-R's Avatar
New User
Default Re: how to replace rear tailight bulb? (B2FiNiTY)
thanks for the help and the sarcasm...already done
SteveP
Nov 26, 2017 01:19 PM
redblue17
Feb 9, 2009 07:26 AM
lv6l
Nov 2, 2005 05:11 AM
chuckus
Jun 22, 2003 09:38 PM
KF_S2000
Feb 1, 2002 08:51 PM
