Trouble with H23a swap in 2000 ek coupe
Alright what's going on guys, so I have ran into a little bit of trouble with my swap. I had ordered axles offline off of procivic.com ones that are compatible with my swap and car and I ordered an intermediate shaft and it came with no carrier or even carrier bearing I'm being told I can't buy the carrier separate, so now I'm wondering if I can't get a carrier for my new axle what do I do? What is the intermediate shaft I need with the carrier for my car? I really don't know what to do and I'm wondering if anyone can help me or has into this problem themselves?
Alright perfect thank you, and since it's an H23 not H22 I would need the half shaft from a 96 prelude si not prelude s right? And the carrier for that should most likely work right?
All 3 models of '96 Preludes would actually use the same intermediate shaft. The '92-96 shaft has a steel bearing housing and the '97-01 shaft has an aluminum bearing housing. Any will work for you assuming you ordered axles that are for an "H" swap in an EK chassis.
freak86
Oct 20, 2006 07:51 PM
