Custom axles for gsr swap
Old Feb 24, 2017 | 04:55 PM
Nick Giannini's Avatar
Default Custom axles for gsr swap
Hi, do I absolutely need customs axles with a jdm b18c swap in a 90 civic si? I have had a problem with vibration in the steering wheel and a litttle shaking upon high acceleration and was told the 95 gsr axles are a too long and causing the problem. I wanted to know if I had to have innovative custom made for a grip of money or another setup for axles / half shaft combo. Thanks
Old Feb 24, 2017 | 10:11 PM
king06's Avatar
Default Re: Custom axles for gsr swap
Absolutely not. You probably just have bad Axles.
Old Feb 25, 2017 | 09:44 PM
netfreak's Avatar
I'm running 94-01 integra axles and half shaft in my CRX with no problems. Did you knock out the dust rings or whatever they're called? Could have binding issues if you didn't (see https://honda-tech.com/forums/honda-...-rings-338967/)
EFDRAG
Mar 13, 2019 01:32 PM
mrbutters
Mar 15, 2009 05:49 PM
jerzeytib
Oct 22, 2003 08:49 PM
