P0505 After New IAC Valve
I was having problems with a sticking valve and hunting idle, so I replaced the IAC valve. However, it idles correctly most of the time, but sometimes it will let the idle go up to 900 which sets a pending p0505 code. Any ideas as to why this might be?
It also has ABS codes 31-2 (PFINH signal malfunction) and 34-2 (TPS sensor). The TPS reading is 9.8, which I thought is still acceptable.
Any ideas?
Any ideas?
accordisslow
Jan 22, 2006 08:27 PM
