Fifth gen multiple miss fire
Old Feb 23, 2017 | 03:39 AM
skippy33's Avatar
Default Fifth gen multiple miss fire
2001 h22a4 gets warmed up and starts to misfire put computer on it says multiple cylinder misfire was only doing it when it was warmed up now starting to break up all the time replace distributor cap roater plugs wires coil any help would be much appreciated..Thanks
Old Mar 4, 2017 | 02:19 PM
homercan2's Avatar
Default Re: Fifth gen multiple miss fire
Have you checked your timing?
Old Mar 5, 2017 | 12:50 AM
holmesnmanny's Avatar
Could be the crank sensor either caked up with carbon or just flat out bad. You should pull it and take a look and/or replace it.
Old Mar 9, 2017 | 03:45 AM
skippy33's Avatar
i will double check just put a timing belt in a couple thousand miles ago
Old Mar 9, 2017 | 03:46 AM
skippy33's Avatar
thank u I will pull that and look
Derrick_12341
Jul 26, 2018 07:15 AM
Christopherian1982
Mar 28, 2011 11:35 AM
steve495
Dec 14, 2004 05:22 PM
nayrone
Nov 1, 2004 07:21 PM
gupta_p
Nov 25, 2003 10:15 PM
