last hope for a 91 hatch project DOHC ZC AXLES
Old Feb 22, 2017 | 06:04 PM
mikesphat's Avatar
Default last hope for a 91 hatch project DOHC ZC AXLES
hi all, i have been working on my DOHC ZC for a bit(91 std hatch)
the engine was purchased in 04 from hmotors... the tranny in 2016
the intermediate shaft doesnt line up with the bolts on the block... and hmotors hasnt really shown an interest in making it right YET
what are my options? i have a 4 speed from the original car... can i swap the internals and use stock axles?
raxles told me im fucked without the intermediate
so i have a $550 dollar paper weight
Old Feb 22, 2017 | 06:49 PM
m90polk1's Avatar
Default Re: last hope for a 91 hatch project DOHC ZC AXLES
a6 5 speed and I don't believe you need any half shaft.....It's been like 10 years since I did my zc swap (same std model with 4spd and dpfi)so don't quote me 100%... or Sell it all and go b20 cheaper and faster
Old Feb 23, 2017 | 01:05 AM
bbarbulo's Avatar
you didn't say what trans you're trying to use? are we to assume both are JDM DOHC ZC units from a Civic?
In Honda Engine Swaps by Aaron Bonk (SA Design books) it says:
The transmission of choice is the Civic-style ZC transmission available with the engine that is purchased. .... It is mandatory to use the intermediate shaft found on the 88-91 JDM Civic ZC; the USDM integra version won't work.
So, which one is wrong? Your engine block or your intermediate shaft or the trans? If it's all 88-91 JDM Civic ZC, then it should go together without an issue. Yes, you can reuse the 4 speed straight up with the axles and all, but I have no idea if the guts from the ZC can be swapped into the 4 speed case. There was some indication on here in a thread that it's possible, but I haven't done it.
Old Feb 23, 2017 | 03:55 AM
mikesphat's Avatar
yea sorry i wasnt more clear... jdm zc motor stamped zc... jdm zc tranny 5 speed... best i can tell is the intermediate shaft is for an auto tranny... it has 9at stamped on it... fits in tranny just fine but the bolt holes on the block are about 1/2" off
Old Feb 23, 2017 | 07:18 AM
24TEN's Avatar
PHANTOM MENACE
Very few people still retain the knowledge for the DOHC specific info, even fewer still using the engine. I couldn't tell you what's different about yours but I can say the easiest way to keep things simple now and in the future is to take the gears out and stick them into an SOHC cable case (if possible the Si one since it will have the higher final drive). That way once it's all together you just treat it like it's a normal D-Series transmission meant for your car.
Old Feb 24, 2017 | 10:42 PM
bbarbulo's Avatar
Can D Series Motor/trans Use Intermediate Shafts? - Swaps - Red Pepper Racing
CRX Community Forum ? View topic - Question about the CRX's drive axle
here is some good reading.
sounds like a 44500-SK7-020 is what you need.
Old Feb 26, 2017 | 05:17 PM
~sp33~'s Avatar
EFB055
You could use any D series trans that has unequal shaft lengths.
cpuff
38
Jun 22, 2017 04:55 PM
88EF4dr
Jul 12, 2011 06:42 AM
1phast1
18
Jul 2, 2005 08:11 AM
31flavorscivic
Feb 14, 2005 01:08 PM
johnclaunch
Oct 21, 2003 11:48 PM
