misfire. Any ideas?
Old Feb 22, 2017 | 02:33 PM
eggie75's Avatar
Default misfire. Any ideas?
Hey all. Give me some ideas.
h22 boosted w s300 w boost control. Ran fine. Sat for 2 years. I have a obd2 ecu w emanage for inspection that was tuned for this setup. Put the emanage in. Swapped injectors for the emanage. Cleaned egr ports, changed egr, plugs, wires, dizzy, coil, map, drained gas and put in fresh. Still misfiring. Any ideas? Have to jump the battery everytime i start it. New battery?
thanks
Old Feb 22, 2017 | 07:57 PM
2kdrift's Avatar
Default Re: misfire. Any ideas?
definitely sounds like it needs a battery start with that and see if problem still continues. what did you set plug gap to?
Old Feb 26, 2017 | 09:34 AM
eggie75's Avatar
New batt now. Still misfiring. Plugs at .30. Gonna try oem ecu w stock injectors and pull off ic pipes. Will 9:1 w stock injectors misfire too?
anon191
17
Jun 25, 2013 10:33 AM
SSU76@aol.com
Jan 28, 2013 07:45 AM
jmflyd
19
Aug 13, 2009 07:58 AM
dmpd_ef
May 18, 2007 11:39 PM
