Koni Yellows question! Need help.
Old Feb 21, 2017 | 10:33 AM
99Ek_Fred's Avatar
Default Koni Yellows question! Need help.
Bought a brand new set of Koni Yellows today off some dude on Craigslist. He gave me the receipt as well in case I ever need access to Koni's lifetime warranty. I was under the impression that 92-00 civic shocks and struts were the same as 94-01 integra. Though according to pages such as Amazon and eBay the rear shocks (8041 1153 sport) do not fit 99-00 civic ex? The front shocks (8041 1152 sport) are said to be ok by Amazon. Anyone have any experience with this? The rear shocks are supposed to be fit 92-95 civics but will they fit my 99 ek? Please help
Old Feb 21, 2017 | 11:15 AM
LiteraCola's Avatar
Corvette Forum Member
Default Re: Koni Yellows question! Need help.
I once made EK shocks fit an EG. I had to cut the rear LCA's (just notch them) to make the shocks fit. The lower shock ears on the EK longer than those on the EG. Nothing a side grinder can't fix!
Old Feb 21, 2017 | 01:07 PM
99Ek_Fred's Avatar
well im trying to put E.G. shocks on an Ek. I've read that you could use two washers on each side of the control arm to make the shock fit. Does anyone have any experience with this or know where I can find these washers?
Old Feb 21, 2017 | 01:18 PM
LiteraCola's Avatar
Sorry; I had that backwards. I made E.G. Shocks fit an EK. I believe only the fronts are interchangeable without modification. The rears, like I said, won't fit.
Old Feb 21, 2017 | 02:27 PM
Eight09's Avatar
The front are interchangeable but the rear require some grinding of the EK's rear lca bushing to fit
Old Feb 21, 2017 | 02:42 PM
99Ek_Fred's Avatar
I've been doing my research and EGs require to be shaved to fit EK shocks. Not the other way around. EK apparently you can either switch out the bushings and put in E.G. bushings or use washers to fill up the gap
Old Feb 21, 2017 | 02:43 PM
Kyle Johns's Avatar
The rears will fit on an ek with washers (don't recommend) or thicker bushings. Or integra rear lcas
Old Feb 21, 2017 | 03:32 PM
99Ek_Fred's Avatar
i know washers aren't recommended but it seems to be the easiest fix to the problem. Many people recommend washers, why would you say no? I've also heard that integra and eg lcas should not be put on Eks because they're different.
Old Feb 21, 2017 | 04:45 PM
94EG8's Avatar
Seagull Management
You can use washers or spacers. Some companies, Tokico being one of them, only make one set of rear shocks for EG/DC/EK and include spacers so they can be used on an EK.
An no you can't swap LCAs as they're different lengths.
Old Feb 21, 2017 | 07:10 PM
99Ek_Fred's Avatar
I've been searching for those tokico spacers but I can't seem to find them anywhere online. You think I'd have to call Tokico? Or will any stainless steel washers from a hardware store work?
Old Feb 21, 2017 | 07:15 PM
99Ek_Fred's Avatar
How did u make them fit? Any specifically sized washers that you used? Or did you use spacers? So confused don't know what to get for them.
Old Feb 21, 2017 | 10:22 PM
baller status's Avatar
There's nothing magical about the washers. They just take up the free space on the bolt on the inside of the lower strut fork. If you don't put washers in, torquing the bolt causes the fork to deform inward.
Old Feb 22, 2017 | 02:27 AM
94EG8's Avatar
Seagull Management
Washers will work fine or go to a machine shop and get some slices of 3/4" cold rolled with 10mm holes drilled in them for spacers.
Old Feb 22, 2017 | 03:02 AM
LiteraCola's Avatar
Back when I did it 5 years ago, I didn't use washers. I used a cutoff wheel to notch out the LCA and they fit fine.
It's an M10 x 80 bolt, so just get a few M10 washers (stainless if you're worried about rust) and stick 'em in there. And try to keep the amount of washers even on both sides. Don't bunch them all on one side so as to keep things even.
Old Feb 22, 2017 | 03:32 AM
99Ek_Fred's Avatar
Awesome man, thanks a lot. I thought I was doomed and just wasted money on some koni's. have a good one mate
Jlamar757
Suspension & Brakes
Apr 6, 2006 08:33 PM
run-it-red
Sep 15, 2005 05:43 AM
run-it-red
Suspension & Brakes
Sep 14, 2005 01:17 PM
need2buyaR
Feb 13, 2003 01:48 PM
ichibano
May 15, 2002 07:38 PM
