Honda Civic hatchback for sale.
Selling my Honda civic hatchback.
Built it for the track but you can drive it on the street. Runs and drives just fine. Made 450hp on pump gas. Never put race gas. I built it for my wife and she only drove it for a little bit. I wanted her to get comfortable with the car before we put race gas in. Have dyno sheets. Started prepping the car for paint but left it as is with primer. Will need a paint job. Needs new mirrors as well.
Engine, turbo and drivetrain info:
B18c1 bored to 84mm golden eagle sleeves.
9.5:1 cp pistons
Manley turbo tuff rods
Full Ferrea valve train
Ported and polished head by port flow
Edelbrock intake manifold
70mm throttle body (may be larger)
ARP head studs
ATI dampener
Skunk 2 cam gears
Skunk 2 tuner 1 cams
ID 1000 injectors
Aeromotive fuel regulator
Walbro 255l fuel pump
Tial blow off valve
HKS 60mm wastegate with 18 lb spring
Custom top mount
Precision 6262 T4
Precision 750hp intercooler
MSD 6a and blaster coil
Quiafe LSD
GSR transmission
DSS 5.9 axles
ARP extended studs
3" turbo thermal exhaust
Fluidyne radiator
Hasport motor mounts
AEM wideband
Hondata S300
Tuned by Mase engineering
I'm sure I missed something but you can ask.
$6,600 car as is. $7800 and I will have the car repainted red by a professional and no not a cheap paint job.
Last edited by BLaCKWiDoWSi; Feb 24, 2017 at 03:45 AM. Reason: Adding transmission info and price change
YumVTEC
May 24, 2004 09:42 AM
