2002 Honda Civic 1.7L Missing
I have a 2002 Honda Civic 1.7L (all stock). It just started missing and smokes on startup. Smells very rich, looses speed while cruising and misses a little while accelerating but will clear out over 3/4 throttle. Scanned it and came up with P0301, P0302, P0303, P0304, P1457, P0300 and repeats of these... I was looking under hood and noticed exhaust manifold is cracked right about O2 sensor (unrelated???). Wondering if there are any ideas on where to start first? It's a 4 separate coil pack ignition system. Help???
Have you removed the spark plugs and looked at them? When was the last time they were changed?
I thought the fueling trim is based on the primary O2 sensor readings. Still a valid thought, but the O2 won't make it so rich that it misses.
When was a valve adjustment last done on this car? Is the air filter clogged?
binglax09
Honda Civic (2001 - 2005)
Mar 16, 2007 02:35 PM
hatchinprogress
21
Jan 23, 2005 08:05 PM
