Knocking noise coming from timing side
My civic is knocking from timing side, wondering what it is before I start buying parts, it's an mpfi converted d15b2 if that matters.
Tried to figure out if it was the tensioner or water pump, then took them both out and they looked fine. The harmonic balancer is missing a chunk
maybe that caused the crank to get thrown of balance, the oil light never came on, no CEL, always check oil levels and the engine was never abused
but overheated once about 2yrs ago. Anything helps, thanks.
When does the noise happen?
is it constant, or happen at certain speeds?
Is there visually anything obstructing anything near the belts?
How many miles?
Are all your timing covers installed?
How many miles?
noise happens after car is warmed up
it stays constant at 800-1200 rpm then disappears anything above that
nothing obstructs the belts
block has 255k but had a "rebuild" dont know what the previous owner meant and the head has less than 70k and fully rebuilt
the top timing cover is removed
here is my vid:
sorry its 2 seconds long i accidently touched the screen with out realizing causing it to stop
hopefully this helps out a little
here is my vid:https://www.youtube.com/watch?v=_RFu9JXWTAs
I took of the drain plug and saw no metal on it, then drained oil and inspected it with a magnet and it was still clean, I'm gonna take of the pan off as soon as I get the exhaust out of way, I'll update with pictures when I'm done, thanks.
The crank seems to be in good shape, aswell as the pistions,rings, and rod journals. Imma blame the crank pulley on being the problem due to it missing a huge chunk causing the bearing closest to the timing belt wear out faster than the others(causing it knock closest to the timing belt)
