honda accord starting issue
Old Feb 12, 2017 | 01:08 PM
dabadas's Avatar
Default honda accord starting issue
I have 95 Honda Accord that when I turn it off and stays off for about 15-20 minutes and I go to start it there is no power to the switch radio or anything. I can take the negative battery cable off for a minute and everything comes back on and the car will start, why is it doing this? Thanks
Old Feb 12, 2017 | 04:45 PM
tamboo's Avatar
10 Year Member
Default Re: honda accord starting issue
negative cable ground could be iffy.
remove and clean it up even if it looks ok.
do not just eyeball it lol.
Old Feb 16, 2017 | 02:33 PM
Faraz123's Avatar
100% Agree, you change the entire negative battery cable by getting a replacement from autozone/pepboys/whatever. It just runs from the terminal down a little bit, very easy swap, only like $15.
Old Feb 18, 2017 | 08:42 AM
holmesnmanny's Avatar
if you have an aftermarket alarm, especially a Viper or DEA, the starter disable function is likely malfunctioning
DarrenWB
Jul 1, 2019 05:28 AM
j9free
Dec 4, 2014 07:29 AM
cars2000
Aug 6, 2011 09:46 PM
richard9
Mar 25, 2008 11:35 AM
