Car cuts off while driving
Old Feb 10, 2017 | 04:26 PM
Shawno100's Avatar
Default Car cuts off while driving
Can anyone give me an idea of what to look for on a 99 Honda Accord Dx stick, while I am driving it just shuts off with out any signs the car has been sitting up for some time using for a work. You help would be appreciated.
Old Feb 10, 2017 | 04:35 PM
tamboo's Avatar
10 Year Member
Default Re: Car cuts off while driving
sounds like ignition switch. you can easily clean it or just replace. only about $50 or so. common issue.
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
other ignition stuff you should stay on top of as it's the weakest link:
Starting Problems
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Feb 11, 2017 | 04:12 PM
MAD_MIKE's Avatar
MM Gruppe B
I would suggest checking the ignition switch as well first.
If you have lots of keys/charms/junk on your key ring it can wear out the switch prematurely. And some of the 98-02 cars had crap switches.
With the engine running, jiggle the key in the ignition switch. Don't rotate it, just move it up/down, fore/aft. If the engine stumbles/cuts out, that is most likely your problem.
Rockauto.com has them for ~$40 + shipping, look for the 5% off discount code, usually covers the shipping.
piepans
Dec 28, 2013 10:19 AM
gwchndlr
Mar 18, 2007 11:09 AM
nowind
Oct 22, 2006 10:17 AM
