Skunk2 Alpha header vs JDM ITR 4-1 Length
Old Feb 8, 2017 | 10:14 PM
HypL's Avatar
Default Skunk2 Alpha header vs JDM ITR 4-1 Length
Hey, does anyone know off hand if the B series Skunk2 Alpha series header (gen 1) and the JDM ITR 4-1 header are the same length?
Reason being, I have 2 integras, a DA and DC with these headers installed and would like to swap them, will this be a direct swap without any modification needed to the cat? Just wanna make sure before I go ahead and start the work, Thanks in advance
Old Feb 11, 2017 | 08:23 AM
TheShodan's Avatar
Moderator
Default Re: Skunk2 Alpha header vs JDM ITR 4-1 Length
It may be best to contact Skunk2 directly for that information.
Old Feb 11, 2017 | 09:00 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Rarely will you find an aftermarket header like the Alpha that you can bolt on with a cat. In fact, I can't think of a single on off the top of my head, I don't even think the real Toda bolts up. You will probably have to have a shop modify the B pipe south of the cat to get it to fit, or you can always run a test pipe. Seeing as how the header is not smog legal, I'm sure you're not concerned with passing smog still.
Tuner Eddy
Feb 14, 2012 08:35 PM
SiShane
Jun 6, 2004 04:35 PM
Cone
Aug 23, 2003 02:13 PM
01nhbgsr
Jul 7, 2003 12:33 AM
2k1 GSR
Jun 17, 2003 05:47 PM
