symptoms of bad piston rings
Hey I have a 2000 integra gsr. I'm currently fixing a p0171 lean code but I'm starting to think I may have a problem with my pistons. My car wont rev past 7000 rpm and its burning a quart of oil every 1000 miles. I did a compression test and the numbers were great all around 210-220. I also did a leak down test and all cylinders were betweens 3 and 7 percent. Has anyone ever had oil consumption, a lean condition and the inability to rev over 7000 rpm. Please let me know if you have what the cause was and how you fixed it. Thanks.
Replace your PCV valve first!
Check your spark plugs and gap size they could wrong or be covered in oil causing a spark issue that would set a cell for limp mode, although its usually set at around under vtec but 7k seems strange.
Take off your map sensor and clean it that could be a possibility.
Check your primary O2 sensor i suspet thats the issue for this is how some have cleared this code also some have replaced the fuel filter to clear it.
Have your injectors flow tested and cleaned at RC and try a new fuel filter first.
Try reseting the ecu by unplugging the ecu or neg battery terminal for a few mins.
