97 Prelude SH Engine Swap
Old Feb 7, 2017 | 07:21 PM
Charles Nguyen's Avatar
Default 97 Prelude SH Engine Swap
I recently bought a 97 prelude sh and on the way home, the engine blew and there is a hole in the block. I wanted to get another engine and I had no idea what engine I and put in there and how to do it. Should I rebuild? Swap? the current engine in it is a H22a4.
Old Feb 7, 2017 | 08:40 PM
TimiK's Avatar
Default Re: 97 Prelude SH Engine Swap
cannot really rebuild it if theres hole in your block...
so your options are - get new SH block or swap JDM H22A or find USDM engine there
see that if you want to keep your ATTS you need SH block/engine or otherwise you need to get swap engine with (base) transmission
Old Feb 8, 2017 | 05:56 AM
snobordboy's Avatar
Moderator
Yup, pretty much you want to find an SH engine, or a jdm type-S swap that has the ATTS setup on the back, instead of the normal transmission and half shaft.
Otherwise, you can swap in a non-SH and transmission setup, but you lose the ATTS system, and the lights will always be on, unless you find a way around that.
preludeman87
Oct 31, 2005 06:43 PM
kotetu
May 20, 2003 07:37 AM
Phoenix1
Sep 28, 2002 12:09 AM
Merlin1068
Sep 26, 2002 09:08 PM
