Slight Over Heating Problem 94 LS
Old Feb 7, 2017 | 01:41 PM
lonelyhighs's Avatar
Icon4 Slight Over Heating Problem 94 LS
Hi guys looking for some advice. I currently am running a B18B LS motor in my ef hatch. I am having slight overheating issues sitting in traffic. It generally never gets quite to H but almost there. It has happened twice now and I am ready to fix the problem before it progresses. Some background info on my engine and cooling system. Engine has around 100k. Water pump looks new but who knows. Engine compression is perfect at 205ish psi across all 4. I'm sure its stock head gasket that hasn't been touched. When the first overheating problem happened I turned the car off immediately and that day flushed the system, added a aluminum radiator and new thermostat. Also wired in my fan to run at the key turn. But today sitting in traffic ( 20+ mins barely moving) the temp gauge started creeping up to H. Turned car off, let it cool off 30+ mins and drove it home when the traffic cleared. What are my next steps? I know my radiator is a half rad out of an EG. If I got a dual thick full size rad would that help? Should I replace my water pump? Run no thermostat or is it head gasket time? Coolant and oil aren't mixing but I do burn a bit of oil and smoke when accelerating.
Picture of my engine
Old Feb 8, 2017 | 04:58 PM
tremblay's Avatar
Default Re: Slight Over Heating Problem 94 LS
Bleed the system again... if that doesn't help, install a new OEM thermostat installed. No pep boys/parts store crap.
The honda thermostats react completely different.... and usually run a lot cooler.
I had overheating problems on my turbo setup... honda OEM thermostat fixed my problems completely.
Old Feb 8, 2017 | 05:48 PM
Whats the quickest way to bleed a B series. Should I run no thermostat in the mean time until OEM one and rubber gasket comes in?
Old Feb 8, 2017 | 08:38 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea just bleed the coolant wait till the car is cold like in the morning take off the radiator cap, jack the front up, start the engine set the heater on full blast and let the car warm up to temp, this is where having your fan switch wired in correctly comes into play, usually whrn the engine is at full temp the fans will kick on, once the bubbles have stop coming out the radiator you can put the radiator cap back on. keep a funnel in the radiator fill hole so coolant doesnt spill out as much, wrap a rag around the base to catch overflowing coolant. make sure both top and bottom hoses are hot and you should be good.
​​​​​​​Sounds like your fans got fried and werent on when you were in traffic causing you to over heat slightly..
Old Feb 9, 2017 | 04:34 PM
tamboo's Avatar
10 Year Member
just bled mine, what a p.i.t.a.
helps if you park on an incline and squeeze the hoses.
get the funnel, mine is clear which is very helpful.
got mine from true blue parts:
Amazon Amazon
lots of good heplful comments there too.
i also noticed more air coming out when i did 2500 rpm for 30 sec then idle for 30 sec.
it can be a long slog just keep at it.
Old Feb 10, 2017 | 04:50 PM
tamboo's Avatar
10 Year Member
another option :
Amazon Amazon
a bit pricey and someone here didnt like it. you could always rent out when done.
ef8 sir rex
Mar 18, 2010 08:14 AM
Rad_Teg
30
Oct 25, 2008 04:15 PM
egzo04
Jun 24, 2008 11:46 AM
quickLSt
Nov 21, 2001 03:41 PM
