Steering wheel interchange
Old Feb 7, 2017 | 05:43 AM
ol' grouch's Avatar
Default Steering wheel interchange
Anybody know if the steering wheel from a 1997 Accord will fit a 1995? There was a design change in '96. They look alike but I thought I'd see if anybody has ever swapped them. A previous owner pulled the stock steering wheel for an aftermarket and I want to get the SRS light out as well as restore the factory safety system.
Old Feb 7, 2017 | 07:49 AM
1996accordlx's Avatar
Default Re: Steering wheel interchange
The splines should be the same. I believe it was the airbag plugs and wiring that was different between the OBD1 and OBD2 cars.
A lot of us swap over either S2000 steering wheels, or EK9 Civic Type R wheels, since they actually use the same spline. In some cases the airbag plugs are the exact same too.
Old Feb 7, 2017 | 10:48 AM
ol' grouch's Avatar
I'm trying to keep my investment as low as possible since I'm fixing a bunch of things previous owners did half way. The brakes alone look like they will run me a good $350 or more. If it wasn't a 2 door, I probably would just part it out. I still need to fix a major fuel leak, replace the exhaust and clean the wiring up some. I'm not really into Honda's as I barely fit in them. Now I have two coupes sitting here at the house.
Old Feb 7, 2017 | 11:32 AM
angrysmileyface's Avatar
I believe 94 - 97 is all the same. I have a leather wrapped wheel off a 97 I am intending to use on my 94 wagon, but I will be reusing my airbag. Most of the changes other than OBD1 and OBD2 were cosmetic such as the hood.and front grill.
Old Feb 7, 2017 | 04:19 PM
ol' grouch's Avatar
I don't have anything to go by as an aftermarket wheel is in the car now. Not even a nice one, or tight. Back around 1974 or so I was hammering down a back stretch coming up on a curve and the steering wheel came off in my hand. The crew forgot to push the lock button on it. I had to use a crow bar for a week to go to the bathroom. There's a '97 in the bone yard with the same color interior. About $35 with the air bag. If the bag doesn't work, I'll find a 9 volt battery and have some fun. I want to make this car as turn key as I can. It doesn't even have much rust. Some, but not much.
ek986
Apr 21, 2009 11:36 AM
JeffNA
Mar 7, 2005 10:40 PM
WiLLMaTiX
Jul 14, 2004 05:54 AM
J T*
Jul 30, 2003 08:18 PM
