JDM B16A motor (2000 miles) w/complete Drag Turbo B16A kit
I purchased a CRX for the purpose of doing a K-swap so I’m selling the Drag Turbo JDM B16A motor that was in the car when I bought it The engine was professionally rebuilt using only Genuine Honda parts 2000 miles ago. The Drag Turbo kit has less than 250 miles on it. You get the complete engine, transmission and Drag Turbo kit from the Type R intake manifold to the mandrel bent downpipe. It is running in the car now so you know everything needed is there. This JDM B16A engine/Drag Turbo combo is capable of 230 - 250whp as is. With upgraded the fuel management is capable of 350hp. Take a look at the pics. This engine is like new inside and out.
The car is in Riverside California at the shop that is going to do the swap for me so if you are in California you can hear the motor run, do a compression test or leak down test or anything else you want. If you are not in California maybe you can get someone from this forum to verify the condition of the motor for you. If not I can answer questions and send pictures. Text me with any questions and if you are serious I’ll give you the shops number so you can make arrangement to hear and see the motor run.
If the motor has to be crated to be shipped that will add $250 to the cost.
Please don't waste my time and I won't waste yours.
All offers by text or PM ONLY.
Offers posted online will be ignored.
Price: $3500
Cell: 678-468-2240
You get all this:
JDM B16A motor w/complete Drag Turbo B16A kit for 1988-1991 CIVIC/CRX
• JDM B16 motor – Professionally rebuilt with 2000 miles on it
o Alternator
o Charge Harness
o Engine Harness
o Stock ECU
o Type R intake manifold
o Type R valve cover
• B16 tranny, USDM
o Complete CV/Axles Included
o Shift linkage
• Drag Turbo B16A kit for 1988-1991 CIVIC/CRX
o Turbonetics T3/T4 Turbo
o Drag Turbo cast turbo exhaust
o Turbonetics Deltagate Mark II Wastegate (7 psi)
o Drag Turbo High Flow front Mount Intercooler with polish side tanks
o Blow off Valve
o Drag Turbo Mandrel Bent high flow downpipe
o Drag Turbo Mandrel bent high flow intercooler pipes
o Drag Turbo Wastegate dump tube assembly
o Drag Turbo Silicon hose and hose clamps
o Drag Turbo High Pressure high flow fuel pump
o Drag Turbo Boost Dependent FMU fuel regulator
o Air Intake Filter
o Map sensor bypass valve assembly
o RC 310cc Injectors
o Stainless Steel braided oil feed lines w/ fittings
o Oil return assembly
o Intake air filter assembly
o All necessary hardware and fittings
Price: $3500
Cell: 678-468-2240
You get all this:
o Alternator
o Charge Harness
o Engine Harness
o Stock ECU
• B16 tranny, USDM
o Shift linkage
o Blow off Valve
o Air Intake Filter
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
