Suspension & Brakes Theory, alignment, spring rates....
Need help with Rdb conv.
Old Feb 4, 2017 | 08:40 PM
Couchwarrior's Avatar
Default Need help with Rdb conv.
hey Honda tech. First off sorry if this thread is in the wrong place but I need some help.
honestly I just don't even know where to begin searching..
i am currently doing a rear disc brake conversion on my 92 Cx hatchback. So far I have just gotten the passenger side drum off but I'm stuck.
if you look in the pictures below you will notice on one of the supports the bushing has entirely ripped off.
How do I go about getting the rubber off or am I just fuc*ed.
This is the arm in between the shock and brake line. You can see my problem. Is there a way to get the bolt out?
and then on the actual chassis the most forward arm seems to be having the same problem just not as extreme. I don't want to continue getting it out because it will actually begin to bend the bracket part or whatever.
I've already hit it with some PO.
is there a way to preserve the bolts or at least get the arms off? id rather not cut it but will if I have to, I do have replacements but I need to get that forward arm off first.
Thanks for your help
-couchwarrior
White_EG1
Jun 8, 2017 11:19 AM
Dreamworx
Jul 6, 2004 08:16 PM
scoobyghost
Jun 2, 2003 11:29 AM
GorData
Dec 2, 2001 04:44 PM
