89 Civic b15b DPFI intermittent No start help plz!
Old Feb 1, 2017 | 04:27 PM
LD McCool's Avatar
Default 89 Civic b15b DPFI intermittent No start help plz!
As the title says I have and 89 Civic that will not start (I bought it not starting). I'm getting no spark. I switched the Wiring harness because it was a little sketchy and I was worried I wasn't getting good ground, it ran great for an hour or so then decided not to start again once I shut it off. It's done this a few times now, but it not started more than it has. I also switched the distributor assembly, plugs, wires, main relay and the ecu. Which what I was told were working days before purchase. I checked the g101 ground, removed it and sanded both components clean and replaced tightly. The main relay I got from a salvage yard, I bought 2 extras so I have 3 total that I've switched between. I'm stumped and this thing is getting me down. I just want to drive it again! Thank you for any help!
Old Feb 1, 2017 | 04:39 PM
tamboo's Avatar
10 Year Member
Default Re: 89 Civic b15b DPFI intermittent No start help plz!
verify coil and icm are good:
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
might want to solder a main relay:
Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
more food for thought:
Starting Problems
89civicguy
Mar 1, 2009 08:22 PM
bowenli
Nov 11, 2007 03:31 PM
TizmPizm
Aug 5, 2006 05:14 PM
180mystic
Jul 25, 2006 10:13 PM
dope93si
Aug 23, 2004 08:52 AM
