where to buy injectors for my 2000 gsr
Old Feb 1, 2017 | 02:59 PM
adk133's Avatar
Default where to buy injectors for my 2000 gsr
I'm trying to find reasonable priced injectors for my 2000 integra gsr but I dont want to buy used. Theres alot of cheap remanufactured injectors but I've had bad experiences with past cars. Anyone know of a good place to buy new injectors or any trust worthy reman companys for a reasonable price? I'm trying not to spend over $300 but If I have to I will. Thanks for the help.
Old Feb 1, 2017 | 03:55 PM
TheShodan's Avatar
Moderator
Default Re: where to buy injectors for my 2000 gsr
Check the vendor section. make sure you state the type of injector and size you're looking for.
Old Feb 1, 2017 | 04:10 PM
adk133's Avatar
​​​​​​​Thanks shodan. By the way I read some of your replys on threads regaurding boost application. I could tell by your knowledge on the subarus (which is where I came from) that your turbo kung fu is very strong.
Old Feb 1, 2017 | 11:12 PM
stiness101's Avatar
Are you still using the stock ones? If you are you could always send them to RC Engineering to have them cleaned/flow tested and any parts replaced on them. I've done it with multiple cars and engines, always had great results.
Old Feb 1, 2017 | 11:48 PM
adk133's Avatar
​​​​​​​yes, I need to pass emissions which is why Im not buying upgraded ones yet. It's funny the honda community really likes RC injectors but the subaru community hates them. I'll deafinitly give them a shot. Hopefully they stock rebuilt stockers. Thanks stiness
Old Feb 2, 2017 | 07:00 AM
TheShodan's Avatar
Moderator
Old Feb 2, 2017 | 04:58 PM
tamboo's Avatar
10 Year Member
free to a good home: 95 gsr factory injectors with only 300k miles.
all test ok for resistance. just send out for refurb and youre set.
pm if interested so i dont miss it.
hitting 350k soon!:w00t:!
Old Feb 8, 2017 | 02:50 AM
PHAT-INTEGRA's Avatar
I'm running RC310cc. I have no problem. My old teammate was running Siemens Deka Injectors on his boosted RSX-S.
Old Feb 8, 2017 | 08:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
OEM ecu wont run those size injectors nor will he ever pass emisions. imo send them out to RC or buy used oem injectors. Id sell you mine but i keep things like that just in case **** goes down lol
Old Feb 9, 2017 | 11:42 AM
TheShodan's Avatar
Moderator
RC310cc are high z. You don't get into low z with Rochester/Lucas styled aftermarket until past 440cc injectors. Stock ECU still won't run them, either way.
Old Feb 23, 2017 | 09:14 AM
Not running a stock ECU. I'm running a OBD1 JDM P30 chipped on a base map. Soon to be tuned on Neptune.
Yes you can run RC310 on a stock ECU I have done it on LS/VTEC and I past emission since my vehicle is OBD2 in my state they just plug the port and scan it. Depends on how you drive it. I have other fuel upgraded components including wide band and fuel gauge. I only use my stock ECU just to get to the emission station. Once I'm done my OBD1 ECU goes back in and plus I only have (1) more emission left that I'm going to wave out. Then I can apply for Historic plates.
Old Feb 23, 2017 | 10:11 AM
TheShodan's Avatar
Moderator
When you have to add in a conditional like the phase quoted in bold as a type of disclaimer to someone.. tells me that going by this concept is not at all good idea for those intending to use their car for the actual purpose of driving on a regular basis and not simply for some emissions check.
That's like telling someone it's perfectly fine to drive with 2 donut tyres on the car for an extended period of time without ever having to replace the tyres you have. It depends upon how you drive it..
I'm sorry but that logic makes no sense, especially when you can easily flood the piston rings and render them useless.
The point of this being..... Just because you can do something, doesn't make it a good idea.
Old Feb 23, 2017 | 01:15 PM
adk133's Avatar
I ended up buying AU remand injectors from autozone for $45 a peice plus I got 20 percent off
​​​​​​​ To my suprise the injectors work flawlessly and my car idle smoother but it didn't totaly fix my p0171 problem so I still can't pass emissions. I have another thread about this issue if anyone has ideas or feels like shareing on that thread please do. Thank you.
Old Feb 28, 2017 | 02:51 AM
I know it;s not a good ideal but I was making a point that it can be done.
zeroptzero
Apr 15, 2019 06:28 PM
2ndchirp
May 24, 2009 07:16 AM
Battle Mike
Aug 3, 2004 09:44 AM
92HB_HB
Mar 20, 2003 08:09 PM
b18cInside
Feb 8, 2003 11:09 AM
