'00 Civic EX No Power Locks except with Alarm Fob
Old Jan 31, 2017 | 09:54 AM
DrewMD's Avatar
Davis Photography
Default '00 Civic EX No Power Locks except with Alarm Fob
Hello All,
I have a '00 Honda Civic EX that i've had for years. has a viper 5000 alarm on it. Door locks used to work no matter which method I used, i.e.: door switch, manual activation, and or the viper alarm remote. Now the doors only lock when i use my viper alarm remote. If I trigger the door switch, nothing happens. If I manually lock the driver door, neither door lock actuator activates. Can't be the lock actuator as they work with the alarm. I've checked fuses, but maybe I missed one. I'm fairly confident there isn't a separate fuse for the door lock switch. I've replaced the door lock switch with two other units and nothing changed, so it's definitely not that. I'm thinking it would be break in the wiring into the car, but I haven't been able to check yet. If I'm thinking about it correctly, the signal from the door switch travels into the car and activates the signal to unlock, sending a signal back into the door to the door lock actuator.
Any thoughts?
-Drew
Old Jan 31, 2017 | 04:50 PM
m90polk1's Avatar
Default Re: '00 Civic EX No Power Locks except with Alarm Fob
The keyless entry module in the driver's side kick panel controls them, trace the wires to it and make sure there is no breaks. If continuity is good from switches to it, power is present and grounds are good then replace the module.
Old Feb 4, 2017 | 05:25 PM
DrewMD's Avatar
Davis Photography
Thanks for the assistance.
I used the factory service manual to test the door lock control module. Didn't notice any problems. Then I got to thinking what both the door lock switch and the actuator have in common, based off of the wiring diagrams. The door lock is supposed to activate when you manually lock the driver's door. So I finally realized they utilize the same ground (had earlier deduced that it wasn't the ground because I was testing it at the module.) I pulled the C556 harness plug at the door (leads to the interior) and pulled back the shroud to reveal the completely broken apart ground wire (#22 on the plug). Also noticed the ground wire next to it had worn through the insulation (power windows ground, #23), so now I know exactly what to fix. Will be a pain, needing to remove either the door or the fender for better access, but a simple solder and shrink wrap job.
Old Feb 5, 2017 | 08:10 AM
m90polk1's Avatar
Good job on the diagnosis
I've seen those wires from the door jams go bad on other vehicles to.
Old Feb 5, 2017 | 12:29 PM
Badcopyinc's Avatar
had a jetta with trunk actuator issues this week.
and I've had a crap load of fords mostly exploders with door jam wires shorting locks and windows.
condor22
Jan 23, 2019 09:16 AM
tobytigger
Aug 16, 2012 09:15 PM
Matt93eg
Audio / Security / Video
19
Feb 26, 2010 06:43 PM
PatrickGSR94
Feb 6, 2009 08:51 AM
GSblueRacing
Feb 18, 2003 10:24 AM
