HELP!!! How to remove brake disk retainer screw without stripping??!
Old Nov 9, 2002 | 10:47 AM
fiebru1119's Avatar
Default HELP!!! How to remove brake disk retainer screw without stripping??!
THREE of my wheel studs just broke on my driver side front wheel. I just took out the caliper and that one braket.. now I need to take out the brake disc. How do you remove those screws without stripping them?? Also, do I need to remove the spindle nut (hub nut?) to take out the disc (i hope not )? thanks
Old Nov 9, 2002 | 10:49 AM
Regular Series's Avatar
Default Re: HELP!!! How to remove brake disk retainer screw without stripping??! (fiebru1119)
Impact screwdriver.
http://www.team-integra.net/ has excellent articles on Teg maintainance.
Old Nov 9, 2002 | 10:57 AM
fiebru1119's Avatar
Default Re: HELP!!! How to remove brake disk retainer screw without stripping??! (risingson77)
Thanks but I would have been done by now if I had airtools.. or at least a compressor
GSRaCeRbOI's Avatar
when I was replacing my Brake rotors I also used an Impact screwdriver to take them out... its a screwdriver where you hit the end of the screwdriver w/ a hammer (impact) and that turns the tip about 20 degree's...
Old Nov 9, 2002 | 10:58 AM
fiebru1119's Avatar
Default Re: HELP!!! How to remove brake disk retainer screw without stripping??! (GSRaCeRbOI)
oh! i thought it was an air device.. im gonna run to autozone and get one real quick and i'll let you guys know what happens thanks!
Old Nov 9, 2002 | 11:00 AM
While we're on the subject...how much does one of these impact screwdrivers cost? I need to do my brakes soon...
Old Nov 9, 2002 | 11:04 AM
GSRaCeRbOI's Avatar
its not an air tool... its just a screwdriver thats driven by force/impact... when you hit the end.. it turns the screwdriver tip about 20 degrees
if you look at this link (below) he's using an Impact screwdriver on the brake rotor screws..
http://www.bseries.net/html/garage/brakes.php
heres what the tool looks like (from sears website).. you can buy it at the local sears or home depot for like $20..
http://www.sears.com/data/product_im...763000-dlv.jpg
heres the product description:
Craftsman 7 pc. 1/2 in. Impact Driver Set
Unique design delivers over 200 ft./lbs. of shock torque to loosen rusted, frozen nuts, bolts and screws. Reverse tool to tighten.
hope this helps
Old Nov 9, 2002 | 11:06 AM
GSRaCeRbOI's Avatar
they cost about $20.. I've seen them at both Sears and home depot.. not sure if they have them at Autozone or Kragen.. then again I don't really look there to buy tools...
Old Nov 9, 2002 | 11:12 AM
fiebru1119's Avatar
just got back w/mine from autozone.. $11.99
we'll see how the quality holds up shortly
Old Nov 9, 2002 | 11:58 AM
eh-D's Avatar
I got mine for less that ten at harbor freight, worked great.
Old Nov 9, 2002 | 12:06 PM
GSRaCeRbOI's Avatar
Default Re: HELP!!! How to remove brake disk retainer screw without stripping??! (eh-D)
yeah I saw it in the HF catalog for like $7.99 after I paid like $20 for mine at Sears... but after snapping over a dozen of HF impact sockets.. I don't really trust their tools anymore..
CrX-WoRlD
Feb 18, 2007 01:55 AM
vinuneuro
Apr 15, 2006 01:39 PM
RX3
Acura TL, RL & ZDX
Oct 18, 2005 07:16 AM
civicd15b2
Mar 29, 2005 02:40 PM
subgeniusdude
29
Feb 18, 2004 10:09 PM
