Manual ecu on my automatic
Old Jan 28, 2017 | 09:41 PM
mrprofits1's Avatar
Default Manual ecu on my automatic
Hello folks. I just bought a few days ago a 93 civic hatch with a d15b7 engine. I have a problem with getting the car out of park so i stick the key in the key hole to be able to move it. I was doin a little work on the car and notice it has a 92 prelude si h23 manual ecu. Can someone tell me what is the stock ecu for my car? Many thanks.
Old Jan 28, 2017 | 09:55 PM
White_EG1's Avatar
Default Re: Manual ecu on my automatic
P06
Old Jan 29, 2017 | 05:06 PM
crazyhorse2011's Avatar
10 Year Member
Loved
LOL so wouldnt the car never shift gears and run like poop?
Old Jan 29, 2017 | 07:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The ,92-95 Civic platform uses a cable control for shift selection... there is little input from the ECU. What you need is a 37820-P06-A5X... X = 0, 1, 2 or 3. There is shift interlock communication inside this ECU that likely will cure your ability to shift from park normally instead of having to use the key manually in the over-ride slot in the console.
I cannot even imagine WHY there would be a 2.3L Prelude ECU in your car in the first place... that is the kind of thing that someone does just to get the car moved from a dangerous place to the safety of your own garage, not run it indefinitely.
Old Jan 30, 2017 | 03:58 AM
mk378's Avatar
The first 3 gears of the OBD1 automatics are mechanically controlled by the transmission itself. The ECU controls engagement of 4th (overdrive) gear and the torque converter lock.
Yes I would also expect that to run like crap due to the different cc size of the engine.
Old Jan 30, 2017 | 08:01 AM
mrprofits1's Avatar
Default Mrprofits1
it runs. But i get very bad gas mileage , have the engine light on.
Old Jan 30, 2017 | 08:02 AM
mrprofits1's Avatar
Default Mrprofits1
thanks alot! Will make sure to get one asap. I got the car like that. I dont know why they did it.
Old Jan 30, 2017 | 08:03 AM
mrprofits1's Avatar
Default Mrprofits1
i see. So no 4th gear for me lol.
TofuCandy
Nov 26, 2011 12:19 AM
dustinO
Oct 7, 2006 04:46 PM
lude1888
Sep 5, 2005 07:26 PM
Goinfasterthanu
Jan 18, 2005 02:43 PM
playboyace35
Jul 8, 2004 03:33 AM
