Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 CRV Shuts off driving wont turn on..
Old Jan 26, 2017 | 02:03 AM
MILKYWEY's Avatar
Default 1998 CRV Shuts off driving wont turn on..
1998 CRV shuts off driving to work and didn't turn back on. before the engine completely died, I step on the gas pedal RPM didn't shoot up. I tried turn back on nothing happened, engine didn't try fire up BUT I did feel it turn over.. it felt like I ran out of gas but I didn't.. I'm thinking it could be either fuel injectors or fuel pump.. I haven't pop the hood yet and try troubleshoot..
.PLEASE HELP...
Old Jan 26, 2017 | 05:28 AM
sf340b's Avatar
5 Year Member
Default Re: 1998 CRV Shuts off driving wont turn on..
Pull the distributor cap off and see if the rotor turns as you turn the engine over.
Old Jan 28, 2017 | 12:53 AM
MILKYWEY's Avatar
found the problem it was the ignition coil went out so I replace hole thing... $260.00 repair
Old Jan 28, 2017 | 11:22 AM
sf340b's Avatar
5 Year Member
OOOh. That hurts. I had the same thing a while back but may have got off a little cheaper including the tow home.
Old Jan 29, 2017 | 10:06 AM
M-benz's Avatar
Out of curiosity , can we just replace the ignition coil by itself ? If so, what is best one out there beside OEM one ?
Old Jan 30, 2017 | 12:58 PM
sf340b's Avatar
5 Year Member
It has been a while and I do not remember exactly what I did.
CRV stopped running, would not start.
No Fire.
Troubleshooting and I replaced the ICM in the distributor.
Lost ability to TS I guess as that did not work and replaced coil also.
CRV runs fine.
All parts were Oreilly specials as CRV is stock.
Old Feb 10, 2017 | 09:27 AM
Alpha_tech's Avatar
Glad it was just the ignition coil.
The cap and rotor on my older CRV had to change the whole cap and rotor and ignition coil.
Old Feb 10, 2017 | 12:30 PM
UK-Kev's Avatar
For anybody else reading this blog, please see the link below on how to diagnose correctly.
Part 1 -How to Test the Igniter, Ignition Coil Accord, Civic, CRV, and Odyssey
Regards,
Kev
Bobn4aples
Apr 27, 2017 04:19 AM
Run Away
18
Dec 30, 2006 06:40 AM
cbp_crx
Nov 26, 2004 10:06 AM
