Suspension & Brakes Theory, alignment, spring rates....
Upper ball joint not tight to knuckle.
Old Jan 21, 2017 | 09:08 PM
derrack's Avatar
Default Upper ball joint not tight to knuckle.
The upper ball joint was not tightened to spec and has warn the knuckle. Do i need to replace both the upper ball joint and knuckle or is the upper ball joint hard enough that only the knuckle was affected?
Old Jan 23, 2017 | 03:11 PM
cruizinmax's Avatar
Default Re: Upper ball joint not tight to knuckle.
Should replace both for sure!
Ron454321
Oct 2, 2009 04:18 PM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
driftam1
10
Jul 28, 2008 07:05 AM
90CivicDaily
Jun 4, 2008 04:39 PM
97hb
Mar 9, 2002 11:31 PM
