squeking noise in steering wheel
Old Nov 9, 2002 | 09:10 AM
x00gsr's Avatar
Default squeking noise in steering wheel
theres a squeking noise when i turn my steering wheel. checked power steering fluid levels and its okay. Is there a leak somewhere or do i need to replace the power steering belt?
Old Nov 9, 2002 | 09:42 AM
mugenracer's Avatar
Default Re: squeking noise in steering wheel (x00gsr)
wheres the squeak coming from, the hub itself or the engine bay, if its the hub, then try WD40 where the steering wheel bolts onto the steering hub, if its in th engine bay the belt may need tightening or else its worn and dried out and may need replacing
Old Nov 9, 2002 | 10:07 AM
redacura's Avatar
yea i have the same problem too.. just recently happened....
Old Nov 9, 2002 | 01:30 PM
RS94's Avatar
Default Re: squeking noise in steering wheel (redacura)
i had the same problem, i just left it alone and it went away
Old Dec 15, 2002 | 12:41 PM
ahead's Avatar
Default Re: squeking noise in steering wheel (RS94)
i have the same problem but i removed my power steering belt a few months ago. sometimes when i turn the wheel it makes almost like a squeek type noise. you guys have any idea what it is?
Old Dec 15, 2002 | 01:58 PM
x00gsr's Avatar
Default Re: squeking noise in steering wheel (ahead)
I asked a honda technician he said "its the cold weather it causes your gaskets to shrink. Thats why you hear that noise" ..Well dunno but i'll wait til it gets hot again..
Old Dec 16, 2002 | 09:13 AM
majeed11's Avatar
theres a technical bulletin about this I think.... Most of us all have it, its covered by warrently. I saw the bulletin in the ITR forum, or somewhere here I believe.
Ya, it has to do with the cold weather and the lack of grease. it gets annoying sometimes.
Old Dec 16, 2002 | 01:24 PM
VTECTIME's Avatar
Default Re: squeking noise in steering wheel (majeed11)
My old 87' Ford Tempo did that... and when i intentionally crashed it into a tree the squeek stopped. As did the car.. for good. Enter 1995 Integra.
Old Dec 16, 2002 | 02:55 PM
AWDxBOOST's Avatar
that doesnt make too much sense. Which gaskets exactly?....mine still does it even after the engine warms up.
Jacob Stanicic
Jul 9, 2018 02:22 PM
transitions
Honda Civic (2006 - 2015)
Oct 4, 2011 06:43 PM
Black Ack
Dec 6, 2006 03:36 PM
garrybloom
Nov 16, 2005 11:50 AM
RuskeR
Oct 30, 2002 05:59 PM
