Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
Old Jan 15, 2017 | 03:57 PM
waynesumner's Avatar
Default Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
I wasnt sure where to put this thread since it isnt model specific or tech related more of a discussion. Anywerds
Stuck on what to build. I have a b16 head, a gsr head and a gsr block. I read a regular gsr will put down slight more power than a poor man type R also what kind of pistons should i run? Aftermarket gsr pistons or type R pistons? Would like others opinions on what to do. I also have a ls crank/ rods and block. Could put ls internals in the gsr block and have a stroked poor man type R? Or build a lsv with a b16 head. Decisions decisions. I jumped into this project without a plan in mind but i do know i want to finish a gsr engine. This discussion is just to get some ideas bouncing around. Let me know what you all think!
Old Jan 15, 2017 | 04:01 PM
.Grimace's Avatar
footwork mastery
Default re: Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
real answer - ls crank in gsr block with some type r pistons with gsr head because slightly higher compression
GDD answer - hondas are for poors
Old Jan 15, 2017 | 05:44 PM
xtrac1's Avatar
rookn00b
I have a a gsr head and a gsr block.
Old Feb 2, 2017 | 05:39 AM
B20VtecVillain's Avatar
Really I think this depends on what your trying to do with the setup. For the most Power out of the parts you have, I would get the GSR block honed to 81.5mm, use some 81.5mm PCT (CTR) pistons, use the 89mm LS crank for a little added stroke, and the GSR head casting for a little added compression. Put that together with OEM bearings, OEM gaskets and some half decent cams (CTR or better) and you will have a solid 200+ HP engine that will scream on track. If your just looking for a fun but simple daily driver, use the LS block/rods/Pistons/crank, get an LSVtec kit, use the GSR head, again for a little extra compression, and have a fun 180-185 HP setup for your street car. "Poor mans" type R is over rated. We get these Type R piston GSR blocks with a stock 87mm crank and B16 head combos all the time and the owners all think it's going to be an insanely powerful race engine (because Type R Pistons, duh) but in the end they spend twice as much money to make the same Power a well built OEM part LSV would make.
Old Feb 2, 2017 | 10:51 AM
SolAssassin's Avatar
If you use that LS block you will have to run a catch can as you would have no PCV system with an LS block / VTEC head. And an oil line kit.
Old Feb 2, 2017 | 10:57 AM
This. But you may need to modify the crank to clear the squirters. That setup would make the most power.
Frankly if I had a complete GSR I would just go with that. Why not just put the GSR together and slap the B16 head on the LS block? Wouldn't that make sense? 2 engines right there.
Old Feb 3, 2017 | 07:25 AM
TheShodan's Avatar
Moderator
It's skip the squirters completely if going with an LS crank, and not modify the crank itself. "moving" the squirters is hit/miss, so I'd get a Golden Eagle oil squirter block kit and go from there.
Old Feb 15, 2017 | 12:27 PM
Lau Cac Bo's Avatar
bore block, balance crank, 85mm rs itr pistons.
Old Feb 15, 2017 | 01:01 PM
93egSLEEPER's Avatar
For GSR or LS block? Are you high?
Old Feb 15, 2017 | 07:51 PM
Lau Cac Bo's Avatar
Sometimes I'm high, yes. 85 mm sleeved.
Old Feb 16, 2017 | 02:13 PM
Default Re: Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
Lol ok. SLEEVED makes better sense. B20 block IMO is a better option if cost is a concern.
carlossolorzano
Nov 5, 2010 07:23 AM
jordan_civic
Dec 4, 2007 03:31 PM
xxnuttybarxx
Oct 25, 2007 01:04 PM
bnut510
21
Jul 2, 2007 09:47 AM
mymeatb18"
May 5, 2006 08:02 PM
