1995 acura integra will crank but wont start
Old Jan 14, 2017 | 05:30 PM
james myers's Avatar
Default 1995 acura integra will crank but wont start
I need some help i have replaced everything plugs wires distributor cap rotor button and ignition coil ignitor computer main relay everything is working but still womt start help
Old Jan 15, 2017 | 04:08 AM
7rrivera7's Avatar
Default Re: 1995 acura integra will crank but wont start
Try swapping the ECU to rule it out...
I repair ECUs daily with the issue that when you turn the key right before "start", the main relay does not engage, the fuel pump does not prime and the check engine light will be on solid. If your ECU is doing this, it need to be repaired.
Old Jan 15, 2017 | 04:30 AM
testify's Avatar
On vacation
Is there gas in it?
Can you hear the fuel pump running?
Old Jan 15, 2017 | 10:37 AM
I changed the ecu already still nothing and yes i put 5 gallons in it already changed fuel filter and i put a new main relay in it fuel pump is working
Old Jan 15, 2017 | 01:40 PM
So heres an update car will start after i take the main relay out and reinstal it and it will act like its starving for fuel and then pick up and run fine any suggestions????
Old Jan 19, 2017 | 12:08 PM
civic-steve-94's Avatar
I had a similar issue with my civic, Put two or three different main relays in it and they would last a few days then issue would return spitting trying to die. The ECU was my issue If you remove the ECU cover and look at the large Black cylinder resisters, If there is any brownish discoloration they are on their way out. Also with the main relay remove the cover and look for the same brownish discoloration around the solder points if there is any same thing on its way out.
badtagz562
Feb 11, 2014 05:50 PM
88LsRex
May 29, 2012 03:41 PM
Si-Samuri
29
Jun 19, 2008 05:48 PM
91d15bvtec
Jun 28, 2005 01:42 PM
AgentJam
Aug 15, 2004 03:07 PM
