2008 EX-L backup camera
I have an 08 EX-L with nav and the backup camera died, it was getting fuzzy then got completely blurry and is now just a black screen. I called the dealer and a new camera from Honda is a $1000. Question is does any company make and adapter to use an aftermarket camera and hook it up to the factory headunit/wiring? I tried looking but couldn't find anything.
Perhaps before looking to replace the camera part, I would recommend looking at the connector between the wiring and the camera itself in the lift gate. It could be a loose connector or some corroded pin in the connector that could be cleaned. I found a similar problem that someone had in another forum related to a Honda with a backup camera issue that might be helpful (see the link below). If anything, it might help you identify a few troubleshooting approaches to determine if it is really the camera that needs to be replaced.
08 EX-L Rear Reverse Back-up camera displaying blue screen not working PIC
I wish you the best!
I had the camera out and the connections were clean and tight in the connectors(unfortunately). It was worse after rain so I thought/was hoping the camera was just getting some moisture in it and I'd be able to seal it but it never helped. Thanks for the link though.
hialeahzbg
10
Feb 23, 2010 07:44 AM
