Honda CR-V & Element 2WD & 4WD Element & CR-V
Turn signal lights
Old Jan 14, 2017 | 08:05 AM
mary thompson's Avatar
Default Turn signal lights
Old Jan 14, 2017 | 04:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Turn signal lights
What year and model is your car?
Describe some detail of the issue.
Old Jan 18, 2017 | 10:29 AM
I have a 2007 Honda cr-v. When I turn either way both turn signal lights come on. They do not flash fast and shut off when I turn. I changed the bulbs. Checked fuses and they were okay.
Old Jan 21, 2017 | 02:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
When the hazard lights are turned on, does the signal lights blink?
The flasher circuit is part of the Multiplex Integrated Control Unit (MICU), which is part of the under-dash fuse box on your model year..
Old Jan 24, 2017 | 08:10 PM
No. Only the emergency lights come on.
Old Jan 24, 2017 | 08:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
So, the emergency lights only come on; but, do not blink? Correct?
Old Jan 27, 2017 | 06:57 PM
The emergency lights come on and they also blink. They work just like they are suppose too.
Old Jan 27, 2017 | 07:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Since the hazard lights (emergency lights) blink and work like they suppose to, the turn signal issue may be due to the combination light switch/turn signal that is located on the steering column, or there is a wiring issue from there.
The turn signal/hazard flasher are part of the same component in the under-dash fuse/relay box; so, that is probably okay.
Christinaace
Lighting
Feb 27, 2015 08:35 AM
freelancer799
Honda Civic (2006 - 2015)
Dec 19, 2011 06:38 AM
newbbsauce
Jun 27, 2008 05:49 AM
SPOOLINmatt
Aug 30, 2007 06:41 PM
