Vibration after swap
Old Nov 9, 2002 | 06:37 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Vibration after swap
Just wondering if anyone else has had a noticeable increase in vibration after doing a swap. I have a 93 EJ coupe, with a B20 with jdm b16 lsd trans. The motor, tranny, clutch assy are all stock. There is a noticeable ibcrease in vibration, esepecially when cold. At first I thought it was the missing front transmission mount, but I have since replaced this part. There is also a missing a/c bracket to frame mount, but could this mount really cause that much vibration? Also it seems to level out around 2000-2700 rpm, anywhere else in the entire RPM band, it's there. It's also quite a bit worse when cold. This is not totally unbearable, but it is rather annoying. Any help is appreciated.
Clayton
Old Nov 9, 2002 | 08:45 AM
Slopoke's Avatar
Default Re: Vibration after swap (Clayton)
My advice would be, first, get the bracket you are missing.
Then find a service manual. There is a certain order that you are supposed to follow when torquing down the motor mount bolts, to help decrease vibration.
prjdmek
Jun 2, 2010 07:40 PM
ridgeapd
Aug 21, 2009 06:21 PM
4n_intelligence
Jun 21, 2009 12:00 PM
stevew84
Jun 24, 2008 10:17 AM
GQej1
Jul 7, 2007 06:50 PM
