Re: Driver side wheel tilted badly inside fender (please help)
lower ball joint- get a large prybar/screwdriver, stick it between lca and knuckle. Try to seperate them. They should not seperate, if they do, the ball joint is bad.
tie rods/radius rods- grab hard and yank. There should be no play.
Wheel bearing- wheel bolted on and off the ground, grab at opposite ends and yank. There shouldn't be any irregular noise
axles-click when turning=bad
struts/shocks- typically popping noises=bad
Very easy fix, just get new upper control arms. I'll attach a link of some OEM replacement ones that I am currently running and have been great to me. New arms come with 2 new bushings and the main ball joint (where yours snapped off). You will get them in the mail and be able to bolt them on right away 👍🏽 All for $55 gotta love hondas!🤗 http://m.ebay.com/itm/Acura-Integra-Civic-Two-Upper-Control-Arm-W-Ball-Joint-/190811627723?fits=Year%3A1991%7CMake%3AHonda%7CMod el%3ACivic&hash=item2c6d4260cb%3Ag%3ANWYAAOxyzHxRQ iUa&_trkparms=pageci%253Ae819a61f-d6f7-11e6-a5b4-005056b252d0%257Cparentrq%253A86e85c501590a7870bca aefbffba226d%257Ciid%253A3
Sorry I meant to attach it the first reply my bad! 🤦🏽*♂️http://m.ebay.com/itm/Acura-Integra-Civic-Two-Upper-Control-Arm-W-Ball-Joint-/190811627723?fits=Year%3A1991%7CMake%3AHonda%7CModel%3ACivic&hash=item2c6d4260cb%3Ag%3ANWYAAOxyzHxRQiUa&_trkparms=pageci%253Ae819a61f-d6f7-11e6-a5b4-005056b252d0%257Cparentrq%253A86e85c501590a7870bcaaefbffba226d%257Ciid%253A3
