Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Hard Starting Pilot 2004
Old Jan 6, 2017 | 01:27 PM
rixceu's Avatar
Icon5 Hard Starting Pilot 2004
I have a 2004 Honda Pilot with the following symptoms.
After sitting overnight, the engine starts in the morning with a normal length of cranking. After driving around and the engine fully warmed up, if I shut it down, wait 2 hours, then try to start again, then I have to crank the engine for a long time with two tries, each greater than 5 seconds, before it starts with hesitation, sounding like it doesn't want to start. If I wait less time after shutdown (30-45 minutes), it starts with hesitation after one longer crank. However, if I shut it down and immediately (0-5 minutes later) try to restart, the engine starts normally (short crank, fires right up without hesitation). I've also tried shutting down warm engine, waiting 2 hours, then starting with throttle pedal all the way down (clear flood). The engine did start.What kind of problem might I have and what should I check? Thanks!
feret
14
Nov 21, 2013 08:36 AM
vincsk2003
Feb 21, 2008 07:53 AM
accordv6rider
Dec 21, 2006 02:02 AM
valve79
Jan 14, 2005 06:05 AM
