Where To Buy: OEM Compensator Links
Old Jan 4, 2017 | 06:10 PM
GameBoyeas's Avatar
Default Where To Buy: OEM Compensator Links
Hello,
I'm overhauling the entire rear suspension on my 1990 Honda Civic EF and need to find OEM replacement "Compensator Links". Where can I find them? Rockauto is out of stock and the dealer charges around $66.00 a pop!
I found them for the 96-00 Honda Civics on eBay for $31.08, are they interchangeable with our cars?
Toe Compensator Link Dorman 520-536 fits 88-91 Honda Civic
Toe Compensator Link Rear BECK/ARNLEY 101-6009 fits 96-00 Honda Civic | eBay
Thanks for your help
Old Jan 4, 2017 | 07:28 PM
Marcos Barrios's Avatar
Default Re: Where To Buy: OEM Compensator Links
well at the dealer you would only need two so 132 total
and those would last more than 10 years
those others that you found on ebay i know well also work
but i havent had a same car that long to tell you how long they would last
id say go the cheaper route on this one
yes the 96-00 ones bolt right up
for adjusting the rear tow
Old Jan 6, 2017 | 07:44 AM
Tyson's Avatar
Likely the ek toe arms are a different length. You may run out of adjustment travel unless you can confirm its the same.
No point in getting that if you can get the dormans and too cheap to buy new.
The proper answer is to just buy OEM online at the cheapest price.
highroller54
Honda CR-V & Element
Dec 1, 2013 08:59 AM
chaserz
Honda Civic (2001 - 2005)
12
Jun 21, 2009 07:24 AM
solfire
Mar 23, 2009 08:14 AM
HatchedGTI
Feb 22, 2006 02:49 PM
EG6FF
21
Feb 20, 2003 11:31 AM
