Rocker very tight against valve?
Old Jan 4, 2017 | 11:47 AM
remix919's Avatar
Default Rocker very tight against valve?
I'm having a weird issue with my F23A1 cylinder head, I had disassembled everything to replace a valve and upon re-assembly, I was doing the valve lash adjustments when I noticed that 4 of my intake rockers that sit on the valves are extremely tight against the valve? I had marked timing on the belt and gear so I know TDC is correct on the cam, was wondering if any of you guys had any idea what is causing the tightness? It's just those 4 rockers on the intake side that I circled in red, the other rockers are all fine and I was able to set the valve lash with no issues.
Old Jan 4, 2017 | 01:30 PM
holmesnmanny's Avatar
Default Re: Rocker very tight against valve?
which valve did you replace ?
boosted94gsr
Jun 14, 2014 10:13 PM
raverx3m
May 18, 2011 11:24 PM
rich7777
Feb 13, 2010 05:32 PM
pr3lude1992
Apr 1, 2009 05:33 AM
NA JDM GSR
Oct 17, 2006 10:35 PM
