How to get rpm output in the cab for remote starter?
Hi all,
I'm installing remote starter that requires a rpm signal wire which is a blue wire at distributor. I'm wondering if I can find the same wire inside the cab? Maybe at ecu connector or instrument cluster connector? My car is a 91 manual civic 1.5. It does not has tachometer. I heard people do instrument cluster swap for tachomete4. If this is doable then I am pretty sure there is already a tach wire at the cluster connector. Any suggestions ?
There is a tach wire at the cluster and the ECU. Either one will work.
This should help for the cluster
CRX Community Forum ? View topic - gauge cluster wiring
B16 is the pin on the ECU if you want to go that route
http://civic-eg.com/pics/ecu/ECU_pinout_obd0.jpg
vtechjunkie
28
Mar 16, 2010 11:14 AM
CoreyR
May 28, 2006 08:59 AM
ironchef25
16
Aug 26, 2004 06:55 PM
