My '93 Automatic Accord is Stalling Out...
Old Jan 2, 2017 | 09:43 AM
jmali001's Avatar
Default My '93 Automatic Accord is Stalling Out...
I was gone for 8 days and came back and my car was really reluctant to start and has been ever since. It also stalls out in first gear occasionally, especially when accelerating from a stop. The oil has just been changed. Any thoughts/suggestions would be incredible. Thanks!
Old Jan 2, 2017 | 09:56 AM
GhostAccord's Avatar
Default Re: My '93 Automatic Accord is Stalling Out...
Do you live in a cold climate?
Water in your fuel/bad fuel?
Weak battery/ignition system?
When was your last full tune-up?
Is the check engine light on?
Old Jan 2, 2017 | 10:05 AM
jmali001's Avatar
Fairly cold climate (Albuquerque)
Put in new gas from Chevron
Could be a weak battery
Had a Jiffy Lube checkup, but nothing more extensive in a while
Check engine light comes on when it's cold, but not otherwise
Old Jan 2, 2017 | 10:20 AM
Check your ECU for stored codes. It is OBD1 so there is no quick plug in tool to read the codes. You need to use the Honda Self Diagnostic method to retrieve any codes. if you are not familiar with it. It uses the Service check connector located in the passenger side footwell. it's commonly referred to as the paper clip method.
by GhostAccord, on Flickr
lemdog
Nov 13, 2018 05:00 PM
ahr8tch
Aug 7, 2016 04:04 AM
jcook3890
Jan 3, 2014 02:09 PM
sqwale
Mar 18, 2005 04:13 PM
groove control
Jun 1, 2004 05:58 PM
