CA '98 CRV EX 5-speed
1998 Honda Cr-V Ex ($4200 o.b.o.)
5 speed manual transmission w/ realtime AWD
Sunroof
JVC radio and 12” subwoofer/amplifier
Leather seats
A/C & Heater work
Full size spare
First oil change included with OEM filter and crush washer
Repairs Done:
Interior/Exterior:
· LED interior cabin lights
· New Yokohama Geolander A/T tires with matching spare (less than 1000 miles)
· New front wheel bearings
· New tie rod ends
· Alignment performed recently (Nov. 2016)
· New end-link bushings
· New front disc rotors and pads
· New rear brake shoes
· New upper control arms
· New trailing arm bushings
Engine:
· New motor mounts
· Newer low mileage engine (purchased from JDM of California Inc.)
o All top and bottom end gaskets replaced
· New spark plugs
· New distributor (with warranty)
· New thermostat
· New Radiator, silicone radiator hoses, and OEM radiator cap; used blue Honda Coolant
· New catalytic converter (with warranty)
· New a/c, power steering, and alternator belts
· New idler pulley
· Power steering pump fluid replaced with Genuine Honda Fluid
· New Fuel pump (Wahlbro) and fuel filter.
· Magnetic drain plug
· Compression tested at…
Transmission:
· New Clutch (approx. 1000 miles), new clutch master cylinder, and clutch fluid.
· Transmission fluid replaced with Honda Genuine Manual transmission fluid
· Magnetic Trans drain plug
· Rear differential fluid replaced with Honda Genuine Dual pump fluid
Repairs Needed:
· Horn doesn't work
· Missing headrest for back seat
· Tint needs to be redone
Truck runs great with new lower mileage engine. No over-heating issues thanks to new coolant system upgrades. Air conditioner blows cold in the summer time and heater works great in colder temps. Rest assured that the mechanical operation of this vehicle is sound. Aside from the minor imperfections on the body (expected for a vehicle of this age) the truck rides smooth and achieves great fuel efficiency for a daily commuter. Plenty of storage in trunk for carrying large items. Trunk floor cover turns into a small picnic table, great for camping or trip to the beach. Please pm for questions or concerns, only serious buyers (cash only!). Thanks!
Sunroof
Leather seats
A/C & Heater work
Full size spare
Repairs Done:
Interior/Exterior:
· New tie rod ends
Engine:
· New motor mounts
· New spark plugs
· New thermostat
· New idler pulley
Transmission:
Repairs Needed:
· Horn doesn't work
Fastnfurius13
Jun 12, 2017 09:37 PM
