Honda won't move
Old Dec 30, 2016 | 01:55 PM
Dustin95hondaex's Avatar
Default Honda won't move
I have a 95 Honda civic ex auto and I was coming home from work and car was fine till I got going down the road and at about 60 my car high revved and I could only go into 1 and 2 gear I limped it home and drain tranny fluid and it wasn't burnt no dis color no metal shavings and now it won't move but a inch and thats if I rev it at 7 rpms any idea what to do or what it is ? I even put right amount of fluid back in
Old Dec 31, 2016 | 11:57 AM
civic402lx's Avatar
Default Re: Honda won't move
Any check engine light?
is the gear indicator flashing green?
Old Dec 31, 2016 | 12:07 PM
Nothing on it
Old Dec 31, 2016 | 12:10 PM
No there are no blinking lights no check engine light nothing just netraul idles normal but all the gears high rev
Old Jan 1, 2017 | 11:42 AM
I had one of my buddy's that rebuilds hondas and works at autozone looked at it today rethink the cable to shiftier inside car center console that runs to tranny snapped
Old Jan 1, 2017 | 11:52 AM
civic402lx's Avatar
Wouldn't hurt to check it out. Pretty simple to remove shifter console.
Old Jan 2, 2017 | 07:46 AM
mk378's Avatar
Look under the hood to see if the cable and lever on the transmission moves when someone moves the shift handle inside the car (engine NOT running).
The gear indication lights on the dash are merely controlled by a switch at the shift handle end, so they don't tell you much.
Old Jan 2, 2017 | 10:40 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This is a worse case scenario I am presenting. If your shift cable is still attached and operating correctly and you have been keeping up on your fluid changes (3x3 method). Your fluid could possibly not look burnt and all the clutch disc material has finally worn away preventing the transmission from grabbing.
No CEL would be present being all the valve bodies and solenoids are working properly etc. But with no working clutch discs and recent fresh fluid, the car I believe would behave as you have described of no CEL, clean looking fluid and won't propel the car even though it shifts through the gears.
Old Jan 2, 2017 | 11:40 AM
im just gonna check the cable first but what's a CEL im new to hondas
Old Jan 2, 2017 | 01:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
CEL - Check Engine Light
Also, usually if there is a tranny fault (like a solenoid problem) the D4 flashes. Your's appears to be solid on whatever gear you place it in.
Old Jan 2, 2017 | 03:10 PM
thats why im gonna check cable but thinks for info
Old Apr 2, 2017 | 07:35 PM
Muntheryp's Avatar
Did you find out what was the problem?
mr500cm
Apr 16, 2014 08:49 PM
fryman
Oct 22, 2008 03:51 PM
ReyM
Jun 7, 2006 11:51 PM
deeweezy187
Jun 4, 2006 05:32 AM
CWestinRSX
Jun 19, 2004 11:10 AM
