Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 CR-V Oilpan gaskets replacement !!!
Old Dec 29, 2016 | 05:20 PM
M-benz's Avatar
Default 2000 CR-V Oilpan gaskets replacement !!!
Just curious does anyone here ever replace the oilpan gaskets before ? Any tips or special tools that you recommend ? What gasket brand did you recommend beside OEM Honda one ?
Thanks !
Old Dec 30, 2016 | 02:43 AM
underrated's Avatar
Default Re: 2000 CR-V Oilpan gaskets replacement !!!
Check out the gasket kit with new studs from my Honda habit. It's a lil more expensive, but way worth it.
Old Dec 31, 2016 | 03:21 PM
njn63's Avatar
Eh, I disagree. The OEM rubber part is cheaper and is a much more advanced design than the paper construction of the myhondahabit part.
Slight bias but the new Fel-Pro PermaDryPlus gasket (OS 30630T) for the B-series is what I would go with:
http://www.felpro-only.com/wp-conten...sket_Flyer.pdf
Old May 14, 2017 | 09:53 PM
Hamster65's Avatar
I replaced mine with an OEM gasket and Honda Bond.
KansasKev
Apr 15, 2008 08:17 PM
DA_JDM
Mar 9, 2007 10:03 AM
sacjdmz
Oct 18, 2006 09:21 PM
blowbyu24
Oct 10, 2005 08:57 PM
Hayasa15
Jun 7, 2002 01:17 PM
