D16y5 in a 93 del sol. Help lol
Old Dec 28, 2016 | 07:47 PM
Mikejo's Avatar
Default D16y5 in a 93 del sol. Help lol
I just got a 93 Del sol. It has a d16y5 in it..
Why ? Idk Lol, Problem is it won't fire ( no spark) . It had a td 41 (2 plug ) dizzy on it i took a dizzy off a 97 D16y5 added the harness and still no fire. Donor car was running a good icm coil etc..
All fuses and relays are good.. It has a obd1 ecu
Will engine run off that ecu?
Last Del sol I built was a z6 swap in a 93 S
I built it so I knew what was what..what else cam I look into for the firing issue.? I have 1 hot wire going to coil that's getting power. Is there only 1? Any help wld be great as I need car running and reliable for my son. Thanks in advance
mmunozem1
Jan 26, 2014 02:56 PM
Radon_03
May 6, 2005 12:45 PM
