what honda parts needed for Skunk2 manifold install?
going on a b18c1 2dr gsr
I already have itr throttle cable, and itr bracket.
what other special parts am I going to need, to get this to work?
I would be extremely grateful for yur help
come on people
just because mine has doenst have to do with getting an exhaust or wheels
im sure some tech people in here know the answer
Why would you need the ITR throttle cable and bracket if you're re-using the B18C1 throttle body? You'll need an intake for either an ITR or an LS. Also pick up a new intake mani. gasket, TB gasket and o-rings for the fuel line.
[Modified by LeftCorner, 3:43 PM 11/9/2002]
my friend has the skunk 2 manifold and i think the braket for the throttle cable is all you need. but he actually dosn't have that he just left the strut bar off and it fits.
when i put on my IM on, i cut the cable bracket thing in half and drilled two holes in it cuz the oem bracket holes didn't line up with the skunk manny. i must be a dumbass, but that's the only way i could get it to fit. no problems though.
BobDC2, all you need now is the throttle pulley off a rs/ls or any d series. You can probably get it at a junkyard. ITR/rs/ls/b16 throttle cable is needed because stock one is too long and you can never adjust it right. Glad to see someone is doing it right and not half assed.
Yes, ls/rs/itr throttle cable, bracket and throttle rotor. Also it helps if you have long skinny hands like Mr. Burns, the black metal bracket on the stock manifold is a b*tch!
luckily the engine is out of the car,
I was going to put the skunk2 on my car at a later date,,, but after it took me at least an hour just to get my stock one off. btw, i did this with the engine completely out of my car.
i can not imagine any one actually doing this when the engine is in the car.
its harder than a clutch install
is it absolutely necessary to have itr throttle cable bracket and cable to install blox intake mani?
trustbuddy
Dec 26, 2004 07:53 AM
