which ecu is the best to run with a h22 in a 93 hatch?
Old Nov 8, 2002 | 11:47 PM
p10hlm's Avatar
Default which ecu is the best to run with a h22 in a 93 hatch?
which ecu is the best to run with a h22 in a 93 hatchback?
Old Nov 9, 2002 | 01:39 AM
poison's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (p10hlm)
p13, chipped p28 or chipped p30
Old Nov 9, 2002 | 05:59 AM
eg6ajk's Avatar
JDM P13 by far is the best investment. especially when chipped with Spoon program, which eliminates many of the little mapping inonsicentices and speedlimiter.
USDM P72 GSR is also an excellent choice (94-5 sepcs only), JDM P72 sucks big time, don't even bother you're better off with a chipped P28
Old Nov 9, 2002 | 07:35 AM
2FASTDC2's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (eg6ajk)
I picked up 3/10th's by switching to a chipped p28 from the lude cpu.
Old Nov 9, 2002 | 08:28 AM
HotWheelz's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (YTRY)
what program did you have iwth your p-28 though ?
Old Nov 9, 2002 | 08:37 AM
ExospeedAMcrx's Avatar
GSR ECu will work well.. p72 obd1 only though
Old Nov 9, 2002 | 09:34 AM
satan_srv's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (exospeedAMcrx)
It will also be lean...I wouldn't risk it with the higher compression. P13 is the safest choice. The P28 will also be very lean. Don't be fooled by the power gains..it has little to do with the timing or anything, plus you lose the secondaries with a P28
Old Nov 9, 2002 | 09:59 AM
HotWheelz's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (satan_srv)
secondary's ... put a relay with an rpm swich big deal... to much people over estimate the secondary's ....
Old Nov 9, 2002 | 10:47 AM
poison's Avatar
Default Re: which ecu is the best to run with a h22 in a 93 hatch? (HotWheelz-turboh22dx)
secondaries are not even looked for on the ecu in the first place.
only egr...........and speaking of it. how the hell do you get rid of the egr
btw i have the spoon program on it as well.
mike541
Mar 14, 2011 09:03 PM
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
rohec04
Dec 12, 2006 08:34 AM
hondaguyef
Apr 15, 2004 04:33 AM
prjctCIVIC
Jun 9, 2002 02:57 PM
