why dont my d17 rods fit in a d16y8 block with d17 crank???
Old Dec 26, 2016 | 07:40 AM
Baby99EX's Avatar
Default why dont my d17 rods fit in a d16y8 block with d17 crank???
i thought they r supposed to, but the dont.......help please......
Old Dec 26, 2016 | 08:28 AM
Baby99EX's Avatar
Default Re: why dont my d17 rods fit in a d16y8 block with d17 crank???
no one knows???
Old Dec 27, 2016 | 05:45 AM
v4lu3s's Avatar
RTFM
how do they not fit? You need to actually ask a specific question because we are not sitting there looking at whatever it is you are trying to do.
Old Dec 27, 2016 | 05:59 AM
Baby99EX's Avatar
no i guess im just bitching because loads and loads of people saaid it would work and it doesnt the crank will not spin with d17 rods in a d16 block.
Old Dec 27, 2016 | 08:33 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Check the main journal specifications on the D16Y8 block in the FSM and then check the main journal specifications of the D17A1.
If they are not the same size, then you will run into major problems.
Instead of relying on third party information, you should probably do your own research before you go ripping into a motor blindly. At least then you can be fairly confident of what challenges you will be facing before you get started.
Old Dec 27, 2016 | 08:38 AM
Baby99EX's Avatar
Thanks......
Old Dec 28, 2016 | 05:12 AM
Baby99EX's Avatar
but someone should post which d17 rods will fit in a d16 block, because the d17a2 ones DO NOT.
Old Dec 28, 2016 | 06:49 PM
TheShodan's Avatar
Moderator
You're more than likely going to be the "someone". This is not done as often as you think. Most of what you've researched is theoretical. Now that you'll know the truth, you can post that and positively contribute to the forum, instead of complaining of what's not here. .. That's what experience is all about!
LudaChris
Feb 28, 2007 06:52 PM
raphael
May 25, 2006 06:22 AM
shiftgear8000
Aug 15, 2004 02:42 PM
RyanEJ8
82
Nov 3, 2003 07:53 AM
