FL 2004 Civic VP k-series ready Shell
Hello,
I have forsale my 2004 Civic VP k series shell . I have too many toys and need to rid of some. I have a clean title in hand. 1600 looking for cash only. ! RIMS NOT INCLUDED. Prefer text and email. If you choose to call leave a message and I will reply when i can. 239-410-0475
2004 civic vp edition Fiji Blue pearl. This is the only car and year to come out with this shade of fiji blue ever. I had pulled the stock d17 at 80k miles and only put a little over 20k afterwards. The shell has a tad over 100k miles. paint is still good dents and scratches from daily driving over 6 years.
black interior swap.
rsx-s Subframe
Brembo drilled and slotted front rotors
pretty new ceramic hawk pads up front
Alpine type s front speakers.
Kicker mtx 6x9s in the rear
Hasport esk1 mounts with brand new 94a inserts
Homedepot engine bay bolt washer dressup
red carpet
rear battery tuck kit
03 rsx-s front black leather(driver needs to be re-done)
flat satin black painted enginebay
front plastic bug reflector (discontinued
front paint matched PDM lip bought this for 400 in 08 before replicas were made.
side skirts color matched
k swap throttle cable
brand new oem EM2 master cylinder
steel braided slave cylinder line
rsx-s JVT 3 row radiator
ground control coil settup on stock blown struts
ps delete loop
will include steel blue skunk2 rear control arms (needs new bushings) and a Rare rear white carbing Tie bar
k series ecu conversion harness
Type R EP3 front and rear honda emblem
Will include hks axleback and custom b pipe for k series headers.
32mm Ep3 axles
all appropriate radiator hoses
Will include full rear disc settup minus rotors.
also a k20a3 short block with a k24 steel oilpan with a 10an bung
Underhood webbing removed and sating black paint matched.
aero catch lock and key hood pins just installed.
you would need a full swap (engine,trans,harness,ecu,shift cables, new fuel lines or flare out existing as i cut them by the sibframe)
rsx-s Subframe
red carpet
ps delete loop
32mm Ep3 axles
2000FBPITR
Mar 26, 2011 11:27 PM
Tooch
Nov 5, 2008 09:27 AM
gotboosthatch
Oct 21, 2008 03:39 PM
