Honda b20 crankshaft deep groove
Old Dec 21, 2016 | 05:49 PM
Ryan.2288's Avatar
Default Honda b20 crankshaft deep groove
Hello all,
So to make a long story short I changed the clutch and rear main seal on my CRV with a stock b20. Started leaking so I changed the oil pan and gasket, 3 different gaskets and same leak. Took motor out and came to find that my crankshaft has a groove on in where the rear main seal goes. You can feel this groove with your fingernail. Any suggestions? Am I going to have to have a new cranshaft installed or is there a method of fixing this issue without replacing? Thank you for your time.
Old Dec 22, 2016 | 02:05 PM
motoxxxman's Avatar
Default Re: Honda b20 crankshaft deep groove
I've had this problem before, and my fix was to install a new seal, and just make sure to push it in deeper or shallower than the original seal so the lips don't touch the grooves but rather a fresh surface.
Old Dec 24, 2016 | 12:13 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
x2
This is exactly what my factory trained honda tech told me to do when I run into crank grooves on either the front or rear side.
Same thing can happen on the cam shaft on the gear side. Same trick is the fix.
EG-SIXV-TEC
May 2, 2012 06:28 AM
b20vtechatch
Feb 15, 2005 07:34 AM
erbinone
28
Sep 17, 2003 12:01 PM
Shft@9GSR
Oct 9, 2002 10:25 AM
