JRSC with block breather adapter??
hey guys, wondering if anyone has used this or similar kit with a JRSC. i know the blower comes down the back of the black pretty low. will i have clearance issues with these??
https://www.jhpusa.com/store/pc/view...dproduct=28373
THANKS!!!
THANKS!!!
I'm assuming B-Series?
You've got plenty of clearance on the transmission side. If you've got the OEM oil cooler and your running heat, replacing the freeze plug near the alternator won't work (at least I couldn't get it). I tried several fitting angles, too. Scroll down to post 288 in the following link to see what I mean: https://honda-tech.com/forums/honda-...850586/page12/
Yes B series. Forgot to mention that. Gsr engine. I am not using an "oil warmer" lol but am running heat.
Would my breathing setup be OK, if I use only the hole from the freeze plug near the Trans and the oem nipple. From the valve cover? (and plug the black box hole) ? Or what would you suggest? Would like to avoid the frustration you went through. Lol.
Thanks for the response BTW
whatcivic
Jun 14, 2010 01:36 PM
H4CRXSi
Feb 22, 2010 03:53 PM
