Transmission & Drivetrain Gearboxes, Differentials, Clutches
Can't put car into gear
Old Dec 18, 2016 | 07:51 AM
94ej1coupe206's Avatar
Default Can't put car into gear
i have a 94 civic d15b7, the car can't go into any gear unless I turn it off put it in first then it'll jump and move forward,then the gears will work and car will drive if I force the gears,the clutch pedal is to soft and is sitting close to the floor board, we changed the master cylinder but that didn't help, we changed the slave cylinder but that still didn't work also bled the clutch but still the same..what could be the problem?
Old Dec 18, 2016 | 07:53 AM
Default Re: Can't put car into gear
Only way to drive is this car is to put it in gear then turn it on and it'll jump forward and move ... so I have to turn it off and on every time I get to a light
Old Dec 18, 2016 | 08:00 PM
Jeema's Avatar
Sometimes a clutch disc itself will fail. Pieces of the spring retainers on the disc can break off and then get lodged between the disc and the flywheel or pressure plate.
When that happens, you would get the symptoms you describe. The pedal itself might feel kinda spongy too. The problem may also be somewhat intermittant depending on how the broken piece is lodged.
If you've already replaced the master and slave cylinder, that would be my guess as to what is happening.
Edit: it could still be a hydraulic problem now that I think about it, but if you've visually verified that the slave cylinder is like pushing out when the pedal is down, it's most likely the clutch...
Old Dec 19, 2016 | 09:02 PM
Ok thanks y'all I really appreciate it
Old Dec 22, 2016 | 08:54 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
This is almost definitely the problem.
Let us know what it was when you figure it out OP, brand of clutch would be helpful too.
94ej1coupe206
Dec 20, 2016 07:45 AM
madeinchina
May 16, 2011 12:38 PM
pkdog167
Sep 19, 2008 04:24 PM
lo0nY
Feb 26, 2006 03:58 PM
982drLS
Jun 12, 2004 04:44 PM
